Leaks, leaks and more leaks - sinking
Results 1 to 8 of 8
    Oct 2018
    NY
    As some may know from my other forum i just bought a pair of 2003 cup DIís. Took a while to get running but now they are up and running however each one has a diff issue.
    Machine 1: When I hookup to hose it pours water from some hose under the seat! I wasnít sure if this was an issue when in the water but it was. After 5 mins of riding she was sinking. Btw when on the hose no water comes out of the piss hole in front left of the bow. Seems like a hose is cracked or split. Ideas? I canít see much because itís directly under the seat and up high. Does it on hose or in water running!
    Machine 2:
    All seemed good until it went in the water. I see water pouring from pump area. It was hard to pinpoint because the bildge had so much water but it seemed to come from all around the mount in the rear. Forward of the coupling. I canít tell what type of seal is in there because the mount covers most of it. Ideas?
    Re: Leaks, leaks and more leaks - sinking
    As you state, machine number 1 sounds like you have a hose off, or cracked. You need to find it, and replace.
    Machine number 2 sounds like the carbone ring is leaking where the shaft come trhough the hull (Common). You should be able to tell with the seat off, and running the ski on the trailer with the PTO cover removed.
    I suggest a shop manual. It will show procedures on replacing carbone ring, and coolant hose routing.
    email watcon@watcon.com
    Please visit our web sites
    Oct 2018
    NY
    I do have the shop manual on the procedure. Removing the seat allows very minimal access on the 03 XP DI. I do have limited access under the rear cover but the mount (maybe a carrier bearing) and bracket makes it hard to see anything. I am just not sure where else it could be spraying from. Machine 2 also has an issue where it seems to jump in and out of power band (4900-6000) rpm when at WOT, almost like a misfire or stumble but not exactly. I could always address that separately when i can get it to float, lol.
    Oct 2018
    NY
    BTW anyone recommend a certain brand for the Carbon Seal kit, Link? Something that they actually used and is tried and true
    Oct 2018
    NY
    Any experience with this kit? I would like to go oem but it seems I have to buy each part individually and it’s very expensive, especially with two machines.
    https://bayareapowersports.com/i-248...kaArzuEALw_wcB
    This is mine, Tried & tue;
    https://www.watcon.com/jet-pump-driv...carbone-ring-1
    I do not have them on the site, but I also have complete kits. $75 + s&h
    John
    watcon@watcon.com
    Oct 2018
    NY
    Appreciate it, they just came in and I removed both of the old ones but I don’t see ANY signed of wear
    Frequent Poster daget24's Avatar
    Feb 2013
    santa barbara
    Quote Originally Posted by turbosl2 View Post
    My carbon seal was leaking and my ski almost completely sank. When I pulled out the old one and replaced it, it looked like it had no wear on it, no cracks no damage at all. but replacing it resolved the issue.
    1 2014 seadoo GTR
    1 1996 seadoo gsx
