2003 xp-di
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: 2003 xp-di
    Oct 2018
    NY
    2003 xp-di
    Just purchased a pair of these machines. Was told one does not start. I am in the process of charging the batteries but the description i was given and what it says on the repair order is.
    Inserted Key, beeps two times as it should, press start button, NOTHING, no crank. Tech jumped starter relay, nothing, no crank. Returned to customer.
    Before i start digging into the starter, cables...etc is there anything that is part of the DESS system that would cause this, even if the key is recognized?
    Thoughts?
    Re: 2003 xp-di
    If you jump the starter terminals the starter should crank. That's power directly to the starter terminal.
    May 2017
    New Holland
    Re: 2003 xp-di
    Take plugs out and spin engine by hand to make sure that it is not seized. If not, maybe the starter is bad.
    Oct 2018
    NY
    Re: 2003 xp-di
    Will do, i hope its that easy...
    Oct 2018
    NY
    Re: 2003 xp-di
    The one machine runs, it was sunk but she runs good now. I won’t even talk about that mess.
    The other is an electrical issue. Plug key in...nothing. There is power at battery and solenoid. So I open the electrical box cover and I find a disaster. Wires cut extra something sitting down there. Original had 3 wires new one 4. Wires cut and I can’t seem to locate the 2nd large red wire. See pics. Idk what people are thinking �� B6DAA9D0-2846-48EB-ABED-9540860BFE5F.jpeg648E45C8-1988-405E-B2A9-79946C31500B.jpeg605DECC4-40C6-4B02-820A-8B93AA2DE29C.jpeg
    Re: 2003 xp-di
    Just my opinion but the DI is a HUGE nightmare looking for a place to happen.
    Ditch those POS before you spend too much $$$ trying to fix them. One good thing is you have another to swap parts if needed.
    Re: 2003 xp-di
    The piece with wires cut and new one has 4 is a start relay. I don't quite understand why we need it all?? I've bypassed a couple with no issues. It powers up when the key is put on and allows power through to allow the mpem to trigger the start solenoid. Maybe it's to keep the mpem amp draw from running the battery dead during extended storage periods???
    Oct 2018
    NY
    Re: 2003 xp-di
    So I assume this is why I have no power? Or is the computer and key powered separately
    Aug 2012
    whitby ont canada
    Re: 2003 xp-di
    The DESS has two sides, one controls small stuff like bilge pump, the other side is the ground for that relay which supplies main power for MPEM, as said by Myself it's used to help with power draw when the boat is shut down, I would test that relay and repair those wires, just look up wire diagram
    Oct 2018
    NY
    Re: 2003 xp-di
    Ok that will be my plan tonight. My assumption is the wires were cut to wire in the new relay when he realized he bought a 4 wire relay vs a 3, then stopped
