2003 xp-di - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: 2003 xp-di
    Oct 2018
    NY
    Re: 2003 xp-di
    image.jpgOk so i removed it and beach testing now th be sure itís not the wiring from the handle bar to mpem
    Oct 2018
    NY
    Re: 2003 xp-di
    Black to outer ring - Continuity
    White to center post - continuity
    Black to black/yellow - continuity with key
    black to black/purple - continuity with key
    What other test should happen
    Oct 2018
    NY
    Re: 2003 xp-di
    I am wondering if 2/20 wire is broken in machine since that didn’t seem to have continuity on either pin at mpem
    Oct 2018
    NY
    Re: 2003 xp-di
    Quote Originally Posted by 1957Dave View Post
    OK try this, first back probe 2/12 to battery ground, should have continuity, remove connector 2 ,with key on check 2/12 to either 2/15 or 2/23 should have continuity on one of them, next check 2/20 to either 2/15 or 2/23 should be on the opposite , if that's OK DESS is working, that triggers MEPM to send voltage on 3/9 to pull relay down and send power back on 3/25
    did you mean 2/20 to 2/12 and not 15 or 23? I believe your test doesnít lineup with what the DESS is doing on the bench
    Aug 2012
    whitby ont canada
    Re: 2003 xp-di
    sorry yes, check 2/20 back to MPEM
    Oct 2018
    NY
    Re: 2003 xp-di
    Will do, since it appears my DESS is working if 2/20 is good what would be the next step? Could it be a ground somewhere or is my MPEM shot?
    Oct 2018
    NY
    Re: 2003 xp-di
    double post sorry
    Oct 2018
    NY
    Re: 2003 xp-di
    Dave thanks for the help so far. Could you help me with the principal on how the DESS and MPEM trigger the cut off relay. I am lost as to why when i test my DESS on the bench the 2/12 2/20 and 2/23 all have continuity. Is there not a 12V signal that is suppose to come into here or is it suppose to bridge all these to ground?
    If you could help with what wires are supposed to have voltage and when coming out of the MPEM (particularly 2/12, 2/15, 2/20, 2/23 and how that affects 3/9 and 3/25 i could diagnose this better. Anything you know on the principal of operation would help.
    THanks
  9. #29
    Oct 2018
    NY
    Re: 2003 xp-di
    Problem fixed. Wire at ecu was cooreded and was not making contact.
    Thanks guys!
  10. #30
    May 2017
    New Holland
    Re: 2003 xp-di
    GREAT news! I am glad that you found it!
