95 seadoo xp
Results 1 to 2 of 2
Thread: 95 seadoo xp
    Jan 2018
    Texarkana Tx.
    95 seadoo xp
    Rebuilt whole ski pretty much after piston failure. Problem I’m having is bought oem mikuni rebuild kits, oem 1.2 needles and seats, replaces all fuel lines with thermoid fuel lines, compression is 140 pto 150 mag side if I take fuel line and place in bottle of fuel engine starts right up but sucks a water bottle of gas in a minute or so of running? I’m surprised it even starts also do not see any fuel in pto carb? Also carbs apart have 40 psi pop off pressure on both carbs
    Re: 95 seadoo xp
    Sounds like you still have a carb / fuel related problem.
    Check for internal passage blockage. Possible bad fuel select valve. Did you install internal carb gaskets, and diaphragms correctly? In the OE kits there are multiple fuel pump side diaphragms, and gaskets. Some are for the older Yamaha carbs. If you installed the wrong ones, that can be an issue. Also what spring did you install? On Sea-Doos I re-use the original springs as the ones in the kit are incorrect.
    email watcon@watcon.com
    Please visit our web site
