951 carbed in 3D - Page 4
Page 4 of 19 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 190
  1. #31
    May 2017
    New Holland
    Re: 951 carbed in 3D
    Agree with whaz. Thanks for the update!
  2. #32
    Thanx for looking !!
    Right now working on the fuel tank/system....I wanted to use the XPL tank but the filler neck is different so I am going to use the RFI tank & take the electric fuel pump out & have a aluminum plate made to cover the hole & use a thru hull barb for the fuel line & drill 2 holes for the return & breather fitting.
    I am gonna use the rubber gasket as a template, just waiting for it to get here. Stupid post office can get me a package in 2 days from Cali but takes 7 days from 2 states away.
  3. #33
    I was trying to figure out how to get a barb on each side of the plate so I could drop a line down into the tank & have a barb on top fo connect a line to & found this ....
    http://www.amazon.com/gp/product/B07...0?ie=UTF8&th=1
    Gonna take the nut off & tap into the plate & thread the fitting into the plate.
  4. #34
    May 2017
    New Holland
    Good idea. That should work well.
  5. #35
    The build is still on,I have everything figured out but its on the back burner till I can get a crank & pistons.
    Ebay stuff dont sell so well when its freezing out. LOL No parts selling,no parts buying.
  6. #36
    Hey Grumpy, I may be a little late on this but on the Di to carbed conversions I've done I hade fuel plates made to mount carbed fuel baffles to have working fuel gauges. Just make sure and mark top side cause the bolt pattern is not symmetrical.
  7. #37
    Thats pretty cool...how much ??
    I am having one made by RnR Racing....just a flat plate with a thru nipple setup so there is a nipple on each side.
    Been waiting for a while & not a lot of communication from him.
  8. #38
    Local welding shop made them for me, seems like each time ran about $30. They cut the plate and welded on the pipe stub, I dressed it up and drilled all the holes.
  9. #39
    Sounds reasonable...I will let you know.
    I just want a flat round plate.
  10. #40
    Oct 2013
    funky town
    Send me a picture with dimensions, and required material. I can make it for you.
    I'm only here to make you mad
