951 carbed in 3D - Page 3
Page 3 of 20 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 191
    Re: 951 carbed in 3D
    If by D's you mean di46's then yes we could lol
    Oct 2013
    funky town
    I would say I'm in, but it just got weird. Make sure there's no rubbing.......
    I'm only here to make you mad
    Dec 2011
    Niceville, FL
    I might take the 3rd spot. There is gonna be a need for a good Seadoo wrench in the group
    Good one.
    Oct 2013
    funky town
    Um, guys? In this case, rubbing is NOT racing.
    ....and I always used a hammer on my sea doos. What is this wrench thing you speak of?
    How is this coming along?
    Slow but a little every day...last night I stripped all the unneeded wiring from the XPL wire harness. Eliminated all the extra wiring,no VTS,no gauges,etc.
    Oct 2013
    funky town
    Are the pumps interchangeable? I think they are the same bottom deck, but have not looked into it.
    Yes the 3D was made from the bottom XPL hull that used the 155 pump & thats why the 800 3D was such a dog.
    If the 800 3D would have been made from the 97 XP hull (same hull but used the 140 pump) it would have been so much better. Think about it....a GTX RFI hauls azz because it uses the 140 pump.
    I am gonna use a big hub brass pump with stock prop to get it going & probably get a Solas Concord 15-20 later on. Getting the motor built is the next big $$$ I have to spend & with winter coming not in a big hurry.
  9. #29
    I took the motor out (951) & got it apart. It was rusted up from water intrusion pretty good it took a air hammer to drive the pistons out & then the piston pins.
    Gonna go with ProX pistons,not sure which way to go on a crank. I will probably go with BRP rebuild gonna check price tomorrow. Cleaned everything up & installed the case cooler. I went to tap the holes & they were already threaded & just needed the threads cleaned out.
  10. #30
    Oct 2013
    funky town
    Love to see progress!
