951 carbed in 3D - Page 2
Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 87
    Re: 951 carbed in 3D
    The rear motor mounts are the same all I have to do on the front is...use a stock 951 front mount & drill & tap 2 holes. LOL
    PA
    Out of curiosity, what's in the front that will take a tapped hole and survive the vibration?
    The mounts are screwed in the hull....when they build the hulls the put a piece of aluminum in the glass that is drilled & tapped so the bolt has something to thread into.
    All Seadoo mounts are like that.
    May 2017
    New Holland
    Great thread! Keep the updates coming.
    Sorry if I am jacking the thread a bit, but what are the plans for the 787 RFI engine that came out of the 3D?
    The rfi motor is rusted up & is bacisly a core for a rebuild motor.
    PA
    Thank you! I'm interested in how this works out.
    The aluminum plate in the front was not as big as I thought but was able to modify a stock 951 mount & get it screwed into the plate so I didnt have to do any glass work.
    My next hurdle was a throttle cable long enough with a TPS for the 951...I was able to take the top half of the 3D cable with the TPS part of the XPL cable & turn the cable mount at the carbs around & works like a charm.
    Today I took the banana seat out of the handle pole & without it the spring was overpowering on raising the handle pole thankfully Seadoo put a adjuster screw to adjust the tension on the spring so with it all the way down its perfect not too much up or down.
    I broke the upper pole cover getting it off...the front screw always breaks on these & trying to find one is tough but I always seem to find stuff if I look hard enough & sure enough found a brand new one on Ebay only listed by part #.
    Took the steering all apart & cleaned out the bushings so turns easily & have a new OEM cable to install. So far I have $100 into this build. LOL Trying to use as much stuff I have laying around & off the donor XPL so I am gonna have very little into this build.
    I have my eye on a dead DI 3D that the local Kawi shop has, I was planning a carb engine swap if I get my hands on it.
    Hey if we get one more guy we could be the "3D's"
