Seadoo hx
Thread: Seadoo hx
    Nov 2014
    uk
    Seadoo hx
    Hi just wondering if anyone can help ,can I remove the inner liner of fibreglass,behind were the waterbox sits ,just want to run a straight pipe for a project and not sure if it will be ok
    Dec 2011
    Niceville, FL
    Re: Seadoo hx
    I'm sure you could poke about anything through there if it's well sealed and supported. Your gonna need a riser somewhere in the exhaust though so water can't back flow into your engine.
    Nov 2014
    uk
    Re: Seadoo hx
    Hi Matt, thanks for reply ,yes just didn't want to take it away if it's important to structure ,exhaust will go vertical about 12 inces were it meets the turbo so hopefully that will be enough to stop water flowing into engine
    May 2011
    miami
    Re: Seadoo hx
    He said turbo...
