650sx to sbn 44 throttle cable routing
    Oct 2017
    Discovery Bay
    I am helping a buddy get his 650 running that he recently purchased. I pulled the carb today and it has no idle stop screw and the throttle bracket is bent in all sorts of weird ways. There is no spring on the “arm” so they attached an exterior spring that attaches elsewhere on the ski to bring the throttle back closed, Super ghetto. What is the proper routing of the cable? Should it come from the bottom or top? Also where can you purchase the cable assembly for the carb since this one is jacked? Thanks
    Frequent Poster mjkaliszak's Avatar
    Mar 2009
    michigan
    Re: 650sx to sbn 44 throttle cable routing
    Here this may help you need a few components, John Zigler/Watcon can hook you up I would think. I believe I have bought various components from him over the years. I have broke at least 2-3 SS throttle cable brackets over the last 15 years.... welded a few back together too. Just a heads up good to have a spare. I may have bought a bracket or 2 at SBT also. Install the wheel & bracket on the other side of your 44.
    It was so long ago that I had done this ... I'm not sure what is technically correct never the less this is how I set mine up. The bracket utilizes some of the pump cover screws.
    Oct 2017
    Discovery Bay
    Quote Originally Posted by mjkaliszak View Post
    Thank you this helps!
    Thanks for the kind words mjkaliszak.
    roush611 I do have all needed parts in stock. New multi hole throttle cable drum, cable bracket, new throttle cables, and even used correct return spring and hardware.
    I leave today for Havasu. If you call me early enough I can ship today (8am - 10am your time). Otherwise I am back in the shop mid next week.
    Please visit our web site
    Pittsburgh, PA
    Did you get fixed up? I'm just doing this today and ran the wheel and factory throttle cable and mount on the factory side. It seems to work great, just turned the factory mount slightly so the cable would pull straight.
    Looks good gisak.
