seadoo alignment issue with 95 xp
    Resident Guru slag's Avatar
    Jul 2002
    Lawrence, Kansas
    Trying to align a 720 engine out of a 96 HX into my 95 XP 720 hull using the sbt alignment tool. The engine needs to move to the side more than the holes in the bedplate allow. Is this normal? I walled the holes out a bit and still, needs more work. I'm talking 1/8 to 1/4 or more moving to the right side when looking at the ski from the back. I can't remove the bedplate from the cases as it was a salt water ski and I'm pretty sure the bolts will sheer right off, so that only allows me to wallow out the bedplate to mount holes and it just seems like I shouldn't need to do this to make things fit... right?
    May 2009
    South Carolina
    Re: seadoo alignment issue with 95 xp
    Correct-- any ski that I have replaced the motor on has never needed this but some have been close. Are you sure you can't get it with other adjustments? Sometimes it looks like I don't have enough side to side on the PTO side of the engine but once I look further it turns out to be a height or front of the engine issue that looks like you can't get it aligned.
    Think Big!!
    You know the mounts in the hull move a bit too right?
    Dec 2011
    Niceville, FL
    And the factory would sometimes put shims under the ears of the pump.
    Quote Originally Posted by Matt Braley View Post
    Correct. I find I have to do this quite often on Sea Doos….
    email watcon@watcon.com
    Please visit our web sites
