82 JS550 help
Results 1 to 10 of 15
Thread: 82 JS550 help
    PWCToday Newbie Ryanpb68's Avatar
    Jul 2018
    OH
    82 JS550 help
    ok ready for this bear with me. i can only get this thing to fire on the rear cylinder with the front plug out. i have spark on both plugs. how do you check timing? also my ground goes from battery to intake manifold which is aluminum. would the aluminum have any difference on ground the bolt is steel and is bolted onto the block right so that should be a good ground. runs awesome on one cylinder. try to put plug in while its running and it dies. wont start on both. ive changed plugs, clipped wires. honestly im lost. compression ins 126 on both.
    so from what i can tell its got some mods. im pretty green and im learning so hit me with all the proven knowledge youve got. Thanks for your time.
    Jul 2018
    OH
    Re: 82 JS550 help
    also i did the seadoo 580 starter conversion to rule out the starter. originally thought it was just to slow to start. now the thing has plenty of starter turning it.
    Re: 82 JS550 help
    You could have plug caps or wires that are bad. You need to ohm between both plug caps and tell us the reading.
    SE MI
    Re: 82 JS550 help
    To help in your debug, the coil fires both cylinders every stroke, so if it runs on one cylinder it should be sparking both, check your spark plug caps and get some new plugs.
    Re: 82 JS550 help
    You also should really upgrade to the stock "Jet Power" exhaust. It's way better than the old style you have. I have everything you need to do it too!
    Jul 2018
    OH
    Re: 82 JS550 help
    ok so i ohmed it and it said 15.57. how much do you want for the exhaust and why is it better ?
    Re: 82 JS550 help
    Is that kilo ohms? If so then that 's about right, 5-7k for the coil and almost 5k each for the plug caps. Your head and carb are just screaming for a better pipe. You're not realizing the potential of those mods with that crappy little exhaust. Perform these tests listed on post #4. Let's get it running tight then talk about the exhaust.
    Jul 2018
    OH
    Re: 82 JS550 help
    okay so stupid moment. tried a dif compression tester and well pooh. front cylinder has 90 back has 155 ish. soooo i pulled the engine. pretty simple and fun. its sitting on my bench and im tearing it apart i get the exhaust manifold off and i can see the front piston is ugly goudge and sleeve is very goudge ill post pics here a little later.so how do i tell what the actual size of this engine is. what do i have to measure. also while i have it out and apart what can i do to it to make my life fast and easier later in life. ill take any parts ppl wanna sell. pm me for my phone number and we can exchange info.
    Jul 2018
    OH
    Re: 82 JS550 help
    ok so here are the pictures. pic #1 front cylinder 90psi pic#2 front cylinder sleeve. pic#3 back cylinder 150psi pic#4 back sleeve
    Re: 82 JS550 help
    Hmmmm....that may hone out but I'm worried about the debris damage. Better check out that crank.
