82 JS550 help - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 82 JS550 help
    PWCToday Newbie Ryanpb68's Avatar
    Jul 2018
    OH
    Re: 82 JS550 help
    i have to get a pulley puller tomorrow and ill have it the rest of the way apart. pm me your number if you dont mind i have tons of newbie green questions on what i can do from this point to beef it up any more and im def interested in your exhaust. been fun took all of 12 mins to pull the motor and another 10 to tear it down lol i love these things.
    Jul 2018
    OH
    Re: 82 JS550 help
    and you hear some ugly sounds when you spend the crank something rattling around. What rebuild kit do i want to buy ?
    Jul 2018
    OH
    Re: 82 JS550 help
    also no reeds in this engine? idk im new and green but this ski has lots of mods and im learning someone school me has a aluminum intake.
    Re: 82 JS550 help
    I'm not near the phone much as I work a day job and run my own shop evenings and weekends. I do check up here often and there are many other really knowledgeable folks on here. Best to just keep everything on this thread. You probably have had a crank bearing come apart. I would recommend sending it to a reputeable shop that does snowmobile cranks (same thing) or buying new. I have lost faith in the SBT brand rebuilds cause they use the cheapest crap bearings. I have had good results with PWC Engine cranks out of New York.
    You have no reeds as that is a "piston port" engine. You probaby also have single ring pistons. If you do, they should be replaced with 2 ring versions upon reassembling. Most all jet ski engine parts are aluminum with the exception of the early Kawi standups having cast iron cylinders. While everything is apart is a real good time to true the flat gasket mating surfaces and do some port cleanup, gasket matching. Also at this point you might as well pull and inspect the jet pump. It should feel tight with no play and turn buttery smooth.
    Jul 2018
    OH
    Re: 82 JS550 help
    so im looking now for a replacement 550 motor anyone have one?
