Impros = piss poor
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
    PWCToday.com Is My Home Away From Home spitz15's Avatar
    Nov 2008
    Cleveland, Ohio
    Impros = piss poor
    I’ll keep this short and sweet. I had a prop custom ordered and made by impros. Once i received and measured it, it was competely different than what i ordered. It cost me $515. I asked kindly to send the impeller back for a refund because this is not what i ordered. Their response was “sell it on social media”.
    Impros is a poorly run business and i urge anyone to stay away. Skat Trak is by far worlds ahead of them!
    Im addicted...
    Dec 2014
    SRQ FL
    Re: Impros = piss poor
    Do you have a copy of what you ordered vs what you received?
    Nov 2008
    Cleveland, Ohio
    Quote Originally Posted by StuRat View Post
    Yes i do. Measured back to back. Even someone that doesn’t know how to measure a prop can visibly see a difference with the naked eye.
    i strongly recommend Skat Trak over impros any day.
    Im addicted...
    Top Dog JC-SuperJet's Avatar
    Cypress, TX
    I'm sorry to hear that your expectations weren't met by Impros. And I see by your post count that this isn't your first rodeo...
    It would help if you post a photo of the Work Order with Specifications and the Before and After appearance of the Impeller in question. To show the mismatch(es).
    Why so expensive ($515)? What was the scope of work and what was included? A reconditioning job runs about $100. A remanufactured Impeller with no core runs $100 to $250. Pitch change $100 bucks. Setbacks/Cutbacks extra. Etc.
    But due to the very limited supply of Pro Shops that specialize in modifying, customizing, balancing and remanufacturing PWC Impellers, I have to comment as follows:
    Skat-Trak and Solas have different Blade Pitch Scales. Were you and Impros basing the modifications on the same Blade Pitch Scale? Apples to Apples...
    An Impeller can only be modified by a few degrees. Was your Impeller within safe/possible modification range?
    You asked for a refund but was denied. Was this a one of a kind uncommon unique Impeller? Why couldn't it be sent back for corrections?
    My personal experience with Impros has been good and so too have the local riders'. Need to know how this went wrong.
    The Jetski World is very small and it behooves us all to support the Shops that cater to us.
    Feb 2018
    Manteca, California
    That is strange Dave at improv helped me out a lot I’m not too familiar on impellers but I️ couldn’t get my new impeller 10/16 hooker cut down for a 650 to fit. My old impeller came out just fine and looked almost brand new so I️ was wondering what was wrong save said they might’ve messed up he gave me the measurements and I️ measured and I️t was correct and said if I️t wasn’t correct he would’ve been glad to fix I️t, but I️t ended up being my wearing so now I’m trying to figure out how to fix that
    Jan 2007
    Earth (but just visiting)
    Impros does a LOT of impellers for our shop and we have never had a problem with them or the impellers.
    Oct 2006
    under a ton of work
    perhaps op should supply specifics on this order and what he received.
    impros has always been good to correct any discrepancies .
    Resident Guru jetskichad's Avatar
    Jan 2006
    California
    Not sure if this is the same guy, but saw this posted on one of the Facebook jetski pages for $515.
    Sin City USA
    Modifying to a thin blade setup is very expensive and irreversible.
    Oct 2017
    Wyo
    Bummer man. If it is the setback that they %&%$& up, you could always have a custom seal sleeve made to get the set back where you need it. At least you can do it on a 650 sx.
