is this a good deal?
Results 1 to 10 of 14
    Sep 2018
    Smithtown
    okay, so I have a question I am new to Jetskis and looking to get started on the cheaper side for now. I found someone selling 2 skis on a double trailer all registered. one is a seadoo 98 GTS and one is a Seadoo 97 GTX. On the gts the oil pump does not work so it needs to mix the oil. On the GTX they said the starter button is needed but there is a temporary button wired up. Aside from that on one of them, the HIN does not match the registration 100% only the last three digits. I am told One of them has a new engine with 15hrs. the other has a rebuilt engine 75 hrs. They only want $1500. Should I run away or is this a great deal?
    Sep 2015
    Northern Michigan
    Re: is this a good deal?
    Go run them on the lake and do a compression check. If they wont do that walk away. Do you know what engines are in them?
    Oct 2013
    funky town
    Ho-hum.... Why would you post duplicate threads????????????????
    I'm only here to make you mad
    Sep 2008
    The flakka capitol of Florida
    Does it not alarm you that the hin are incorrect?
    Oct 2013
    funky town
    Nope. Call in the hin on the boat, and run it to see if it's clean. I have a fleet of skis. Most paperwork matches hin's, but ALL the regi #'s match. If the ski hin does not come back stolen, then whatever.
    Although, mis matched #'s are an amazing bargaining chip......
    Sep 2018
    Smithtown
    So sorry about that i put it on the other one as I figured it would get different readers. My bad
    Oct 2013
    funky town
    It posts the same way under new threads, when you log in. No biggie.
    May 2017
    New Holland
    Oh man in PA if the title doesn't match, that is a TRAIN WRECK to get fixed legally. Also, we can not get a registration with out a title. Sounds like a good deal if you are not worried about the numbers not matching.
    Oct 2013
    funky town
    I'm dyslexic and can't count.......
    Sep 2018
    Smithtown
    Ok so now I have a bunch of questions on the HIN. Maybe this should be its one thread...
    Isnít the number on both the motor and the hull? If that was the case and I were to her a new motor then the numbers would not match correct?
    Second part. When you go to register the ski. The dmv does not physically look at the ski so how would they know they donít match?
