Superfreak Badass - 4.3
Results 1 to 10 of 10
    PWCToday.com Is My Home Away From Home BigKahuna's Avatar
    Nov 2001
    Tuscaloosa, AL
    Title says it all. As many of you remember my build thread you can see what all has been done. Tray cut out. All new Stainless lines installed. New Turf with Rear Wedge.
    http://www.x-h2o.com/index.php?threa...-build.178510/
    Carbon Badass -4.3
    XMetal Pole with ADA Steering System. RRP Bars
    DASA 820 6mm Non-PV Motor was build by LPW. Great Power.
    Blackjack 44's. (New Last August) Tau Ceti FA's.
    Advent Ignition with Remote Timing Curve Switch (4 Curves)
    TBM Lightweight Flywheel.
    Torrent 148 Non Setback Pump - (Had small issue with my first one. Brian traded this one out with one I would swear was brand new).
    Prop - Skat 148 9-14 - Just got back from IMPROS for repitch and recondition.
    Thrust Trims system with 85mm Bored Nozzle.
    Cold Fusion E Box Mounting Bracket - Fuel Pickup (New OEM Gas Tank - Fall 2017)
    Boyesen Manifold with Carbon Tech Reeds with R&D Stuffer.
    Mod B-Pipe (2 years old)
    Jetmaniac Waterbox.
    New OEM Motor mounts (Time of build)
    Worx Intake Grate
    2 - Carbon Ride Plates (Toby Built)
    4ba92b045459af3a38b25475d7926433.jpg3c0de3ddf244bb640a3eed3bec72b892.jpg5034c3883b5205491f1ee91df6f7af06.jpgbdd85ab4f8c026128adc7065517b1b04.jpg
    $14,500.00
    I will accept Paypal if you cover the fee's. I will ship if you cover all cost and arrangements. Do have access to loading dock as well.
    Oct 2013
    funky town
    Re: Superfreak Badass - 4.3
    Looking for any trades? Gotta thin the herd before I provide housing for anymore strays.
    I'm only here to make you mad
    Nov 2001
    Tuscaloosa, AL
    not unless you got a Rickter Edge or Newer SJ!
    Nov 2001
    Tuscaloosa, AL
    Hull and Pole with Alum Pump Shoe. $6500
    Sent from my SM-G892A using Tapatalk
    Nov 2001
    Tuscaloosa, AL
    6000.00
    Nov 2001
    Tuscaloosa, AL
    Bump. Weekend only
    $5500.00
    Nov 2001
    Tuscaloosa, AL
    Make offer.
    Oct 2013
    funky town
    Is it minus pump and elect. and motor now? I'd assume so, price wise.
    I would have bagged this complete if we were closer. (but then people would talk......)
    Nov 2001
    Tuscaloosa, AL
    Hull and Pole with chinpad.
    Nov 2001
    Tuscaloosa, AL
    Sold
