2011 Sea Doo GTI 130 Starting Issue
    Jun 2018
    Dexter, NY
    Hello Iíve have been having this issue with my jet ski. It has happened to me three now and Iím at a lost.
    While Iím out on my jet ski it all of a sudden will shut off like I pulled the DESS out. When I go and push the start button nothing happens on the dash. No screen, no beeb no nothing.
    When I check the battery itís good, all fuses are good. Iíve noticed the relay will click multiple times when I push the start button but nothing else will happen. The only way Iíve found to fix it is pull the cables off the battery and let it sit for awhile.
    The last time it happens I also had a IBR failure and it went in to limp mode but I think thatís a different issue because I was able to shut it and turn it back on and it was no longer in limp mode and the IBR worked. I was in shallow sandy water when I started it.
    Please help Iím stuck and Iíve no clue what todo next and I canít afford to bring it to a dealer to have them tell me they can figure it out.
    Iíve read on a few forums that it could be the starter solenoid or the relay or the CDI.
    Re: 2011 Sea Doo GTI 130 Starting Issue
    Replace starter solenoid for clicking issue & replace DESS post for shut off issues.
    Jun 2018
    Dexter, NY
    The starter solenoid isnít whatís clicking its the 30amp relay in the fuse box.
    May 2009
    South Carolina
    Start by looking at all critical connections---major positive wires and motor grounds. Sounds like you have a drop out connection issue.
    Think Big!!
