Engine Bore in PNW? Specifically ~Portland area.
    Frequent Poster rotarypower101's Avatar
    Jul 2004
    Portland/Mt Hood Oregon
    Hey I need to get a 787 bored, guessing 0.25mm over.
    Who do we go to and have a set of cylinders bored?
    I assume I have to do both cylinder equally? To keep them in balance for dynamic weight?
    Do the brand of pistons matter? Do I need a set of teflon skirts like stock, does that even help long term?
    Do I need to purchase pistons Before the bore? Or can they cut them and match them to a set of pistons?
    Type of gaskets matter significantly? OEM VS aftermarket kits like from ebay?Specifically for water jacketed surfaces.
    Oct 2013
    funky town
    Re: Engine Bore in PNW? Specifically ~Portland area.
    Chris Newmiller. Mcn6 is his user name. Hit him up.
    I'm only here to make you mad
    chris newmiller. Mcn6 is his user name. Hit him up.
    x 100
    Jul 2004
    Thank you, PMed him he was quick to respond with follow up and shipping instructions.
    Can anyone comment from experience on the above details for accompanying parts?
    Last time I did this was on a 951, and used mostly/all OEM parts...but if I have some reassurances, wouldn't mind following what others do that is know to work well.
    I use OEM when possible....
