2014 bob gen 3 pro series freestyle jet ski. Runs great tons of power, hits hard. 190 psi in both holes. This is a back flipping machine if you have the balls. $8500 Title in hand. 503-307-1122 heres what it has:
780 RIVA big bore sleeved and freestyle ported 61x cylinder
Flat top pistons
ADA Racing Head Girdled
Head with flat top 190 psi domes
Msd ignition cdi
144 Magnum 12 vein Pump
Im pros hooker large hub high thrust impeller
Thrust innovations easy pull tilt nozzle
Protec extended nozzle
Blowsion throttle trigger.
Blowsion Bars and Quick Turn With Premium Cable.
Dual full spectrum 46mm carbs
R&D intake manifold
Blowsion flame arrestors.
V-Force 3 Reeds.
Lightened Flywheel.
Dakine Forward Foot Strap
Factory B Pipe.
Jetworks Water Box.
Protec Scoop Grate
Carbon Fiber Extended Ride Plate
Aluminum Handle Pole
Hood Straps
Adjustable Foot Holds
Bilge pump
Scupper
Flat top pistons
Msd ignition cdi
R&D intake manifold
V-Force 3 Reeds.
Lightened Flywheel.
Factory B Pipe.
Jetworks Water Box.
Protec Scoop Grate
Hood Straps
Bilge pump
Scupper
