650sx intake pump stuffer thoughts or opions?
Results 1 to 10 of 10
    Jul 2018
    GA
    89 650sx thinking about a intake pump stuffer, how does it effect low end power or is it just for top end?
    Post falls Idaho
    Re: 650sx intake pump stuffer thoughts or opions?
    Does your sx porpoise and hop a lot ? If so , like they all do it will get worse
    Resident Guru still standin's Avatar
    Jul 2009
    michigan, KZOO
    I put the Prowatercraft Pump tunnel stuffer on my X2. now I also changed impeller pitch at the same time so I can't be certain how much effect the stuffer had, but the ski hooks up really well now. Ill be adding the stuffer to my current X2 build as well.
    -2019 SXR - Unlimited Fixed Steer Conversion- 64.8mph
    -86 X2 - Twin carb 750 swap, blaster pipe etc -
    Resident Guru bird's Avatar
    Jul 2012
    La Crosse right on the RIVER
    I just installed the ProWatercraft 650sx Pump Tunnel Stuffer on a Kawasaki TS. It fit just like the video shows. https://youtu.be/GyT2N6AJseQ?t=126
    I will report back later with a test ride once the silicone is dry. I also went from a 15 aluminum impeller to a 10/18 SS Skat. The 15 was very clean, the Skat is almost at the Service limit...bought it used.
    Third Coast Freeride - Midwest Wave Warriors
    Wooka Wooka Wookay. Let's Fing Rage!
    Jul 2012
    Got the ski out last night. I upgraded the carburetor to a freshly rebuilt 44SBN and BCW Intake. I did three upgrades at the same time: Impeller, Tunnel Stuffer, and Carb.
    Before, the ski would just spin the prop if you hit the gas from a dead stop. You had to ease into the throttle.
    Now, it just goes at all throttle positions, off or on plane. I didn't check the top speed. Getting closer to 40 for sure, I'll check tonight.
    Feb 2013
    NorCal
    Anyone else have thoughts on the pump stuffer in a 650sx? I am considering one for my jetmate.
    PWCToday Regular SirGodSpeed's Avatar
    Nov 2014
    Lake Havasu City
    If you comfortable fiberglassing I recommend epoxy filling for the pump stuffer as you are adding weight at the most critical spot to add weight which will help draw the ski in the water and help it stay hooked up. The PWR stuffer is a good but epoxy fill would be better.
    88' 650 X2
    93 750sx Mod
    98 750sxi Pro Vintage Lites
    Sin City USA
    ^Agree w this. The cost is minimal, the results are proven and noticeable.
    Aug 2010
    Edwardsville, IL
    Quote Originally Posted by SirGodSpeed View Post
    I am looking into this as well. Does anybody have a link to a how to? I did a quick search but could not find much.
    2002 Polaris Octane
    1991 Yamaha Superjet
    1993 Yamaha Waveblaster
    PWCToday Guru stonehenge's Avatar
    Mar 2004
    San Dimas
    Been waiting for someone to try this, hoping they get positive results. I'm building a pump for the jm and the last part I was grappling with is this subject. I called the company, and was surprised how honest they were with me, they stated it should work and should help, however they have never tested a JM nor have they confirmed any sales to JM owners with feedback on the install and test ride.
    MAGA 2024
