Largest PWC
Superstore
Collapse
Removing jet pump driveshaft
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Redsharkguy
    • Aug 2018
    • 2
    Just bought a 1995 tigershark 640. Motor runs but needed a carb rebuild so done. Drained the jet pump because it's been sitting a while and drained about 4oz of water and 4 of the oil. Figured it's been there a few years so I'm just gonna rebuild the jet pump. Motors are simple but when it comes to the rest I'm kinda ignorant. How do I get the jet pump driveshaft out so I can get to the bearings. It says remove seal and there is a c clip behind it. Dont have any of the special tools and I dont really want to buy any if I dont have to. Have an abundance of tools I should be able to make it work. Help please!!
  • Associated98
    • May 2014
    • 316
    #2
    Re: Removing jet pump driveshaft
    Well, since they are getting replaced do whatever you need to do to pull those lip seals. I used to screw a long wood screw into the flat part of it and grab it with a vicegrip. Then just yank on it till it tears and comes out. I got nothin on the rebuild part, I've only taken them apart to part out.
    Own:
    98' TS1000R
    97' Daytona 1000
    95' Daytona
    Owned:
    94' Montego (my first) sold
    95' Daytona sold
    95' Daytona parted out
    95' Barracuda sold
    96' Montego sold
    96' Monte Carlo 900 sold
    97' Daytona 1000 clean and beautiful. You will be missed. :'(
    97' Daytona 1000 sold
    97' Daytona 1000 parted out
    99' TS770R sold
    99' TS1100R partially parted/sold
    Comment
    • cleetus
      Top Dog
      • May 2005
      • 1252
      #3
      pull the seals and they tap out.. you will see when its apart
      Comment
      Working...
      X
