98 XPL RPM drop
Results 1 to 10 of 18
Thread: 98 XPL RPM drop
    PWCToday Regular undertaker's Avatar
    Jun 2003
    Freeport, PA
    98 XPL RPM drop
    I need some help with my XPL.
    All stock with the exception of proks, rejetted carbs & "white pipe".
    I was running 7100 rpms for 3 days straight (we were on a family jet ski vacation) and then it dropped to 6400 - 6500 for some reason. Check compression and it was still the same as it was before the rpm drop. Check raves, they seem to be working properly. Reeds are oem and in perfect shape. Ski ran fine but it just would not rev out. It got to the 64-6500 rpm and that was it. This is my first Seadoo and I am at a loss!
    Thanks in advance,
    Ryan
    Re: 98 XPL RPM drop
    Check your pump oil....
    Jun 2003
    Freeport, PA
    Re: 98 XPL RPM drop
    Will do, thanks.
    I kinda hope that isn’t it. I just change oil and the cone o-ring before our vacation. I hope I didn’t screw it up.
    Feb 2004
    Glendora, California
    Re: 98 XPL RPM drop
    Check your RAVEs. 6500 RPMs is what you get with 951s when the RAVEs aren't opening.
    Jun 2003
    Freeport, PA
    Re: 98 XPL RPM drop
    Grumpy was correct, the pump was full of water. So here is my next question for all of the seadoo guys;
    I put on a new impeller/driveshaft boot on the front of the impeller. I put a new o-ring in the back of the pump on the cone but left off the plastic cap that goes over the drive shaft boot. (Rookie) Would this allow the water to come in via the front of the impeller?
    What fluid do you all recommend using to fill the pump?
    Thanks!
    Jun 2003
    Freeport, PA
    Re: 98 XPL RPM drop
    Quote Originally Posted by Watercraft Magic View Post
    We did a check on the RAVEs. Well not me but Scotty Mac did. He said the RPMs dropped to 6000.
    Thanks!!
    Re: 98 XPL RPM drop
    No on the cap on the prop cone....If you need a pump I got a nice big hub bronze one for $325 shipped. Came from a limited XP.
    Gear oil is fine.
    Jun 2003
    Freeport, PA
    Re: 98 XPL RPM drop
    Another dumb question; If the o-ring on the cone is new and the driveshaft seal is new and everything is tight, where can the water be coming in?
    Thank you!
    Re: 98 XPL RPM drop
    Two places,either you didnt get the oring in right or the front seal is leaking.
    Feb 2004
    Re: 98 XPL RPM drop
    Grumpy is correct. Barring any weird cracked pump housing or stripped 1/8" pipe plug thread scenarios of course.
    Either way, you should see if the pump oil cavity will hold 10 psi of pressure for 5 mins or so before adding any oil. But, usually, if it holds steady for 20 seconds even, it's a very good sign. We pressure test every* SeaDoo pump (that gets filled with oil) that we service or have apart for any reason.
    * don't quote me on that
