Engine removal???
Results 1 to 10 of 11
    Jul 2018
    ON
    Engine removal???
    I just baught a 96 sea doo 587 a week ago drove it two or three times and now has low compression on one side and wont run on both cylinders, im going to pull engine out i was wondering how it dissconnects from the drivshaft ? If i lift a little and pull engine away from shaft will they come apart? Do i need to take off clamps? Does the steering jet pump thing on the outside back have to come off to remove engine? Help!!!
    Re: Engine removal???
    Remove the clamps holding the rubber boot at the PTO and push the rubber back. Then remove the engine by tilting it up and forward.
    Jul 2018
    ON
    Got it out thank you!
    Jul 2018
    ON
    Now i just need a site to order my injector delete kit and pistons kit lol!
    I do regular business with JetSkiPlusllc out of Missouri. Tell them PWC Repair of Arkansas sent you.
    Jul 2018
    ON
    Will they deliver to canada?
    Jul 2018
    ON
    Hey i got it apart and turns out my crank rod bearing is shot and moves up an down just on one rod tho , is there a way to take off the rod and install another one with bearing? Or do i have to buy a diffrent crank all together lol? Maby a referbed one???
    Put up a wtb thread. Should find a good used crank reasonably. You can buy a rod kit if you can find a shop to do it. Lots of snowmobile guys up north and the cranks are similar.
    Jan 2012
    Georgia
    I would look for 657 or 717 with the electronics and pipe.
    XI Sport
    GP800R
    X2
    FX140
    I dream skis needforspeed's Avatar
    Sep 2008
    New Jersey
    I wouldn't waste your time or money on that watercraft...been there done that...get a Yamaha or Kawasaki.... just my personal opinion.....
    If it aint broke...don't fix it!!!!
