Gtx popoff
Thread: Gtx popoff
    Top Dog Boz Mon's Avatar
    Jun 2005
    Kankakee River
    Gtx popoff
    Trying to get the pop off right on this 1996 gtx. One carb is right on and the other won’t go above 21psi. Switched needle and seats and springs and every combination under the sun. No matter what, it won’t go above 21psi. Is there some internal part of the carb that could be broken not allowing pressure to build?
    1994 FX1
    1985 JS550/650 conversion
    2015 Fiat 500 Abarth
    Re: Gtx popoff
    If its stock put 95 gram springs & 1.5 n/s & call it a day.
    Jun 2005
    Kankakee River
    Re: Gtx popoff
    It is stock and I did have the 95 gram spring and the 1.5 and it wouldn’t go above 21 psi
    1994 FX1
    May 2009
    South Carolina
    Re: Gtx popoff
    NS arm is bent or needs some adjustment?
    Think Big!!
