Machined impros hooker impeller issue *no call back*
Results 1 to 10 of 12
    ann arbor mi
    Hello everyone,
    Looking to see if someone can help shed some light on an issue I'm having with an Impros Hooker Impeller. I bought a new Impros Hooker big hub impeller and had it machined for a 650 pump. The impeller installs fine in the pump but when I go to install the pump the spines on the driveshaft bottom out before the pump bolts line up. I've tried calling Impros (left a message each time) NO RESPONSE. I'm simply calling to see if there is something I'm doing wrong. My buddies installed with no issues on his. Did they not machine the spines down far enough? Whats the typical response time from Impros? I've spent $315 on something I cant use. Little frustrated.
    Any input is greatly appreciated!
    Top Dog aggrovated's Avatar
    Jul 2008
    Frozen Tundra, MN
    Re: Machined impros hooker impeller issue *no call back*
    chances are, your driveshaft is not seated on the rubber coupler correctly connecting to the motor.
    take the rubber coupler out, put on the driveshaft coupler and hand turn the driveshaft while pushing forward to the back of the motor. you'll feel it seat inward apprx. 1 1/2 inches forward. if needed, just remove the coupler guard housing (so you can see behind the motor).. not needed anyway.
    Quote Originally Posted by aggrovated View Post
    chances are your driveshaft is not seated on the rubber coupler correctly connecting to the engine.
    take the rubber coupler out put on the driveshaft coupler and hand turn the driveshaft while pushing forward to the back of the motor. you'll feel it seat inward apprx. 1 1/2 inches forward. if needed, just remove the coupler guard housing (so you can see behind the motor).. not needed anyway.
    This is the first thing I thought of too.
    ann arbor mi
    Yeah, that was the first thing I did. Even removed the plastic housing to check.
    Jul 2008
    Frozen Tundra, MN
    did you take the o-ring out? impros always stuffs a complimentary o-ring in the impeller splines... sometimes you cant see it in there
    ann arbor mi
    Yeah, O-ring was removed. Sorry to leave those details out.
    ann arbor mi
    Just an Update. They did get back to me and looks like they will take a look at the machining. It must be a time zone delay as to why they weren't answering. A buddy of mine did try to install it on his X2 and same issue.
    This was never a thread to bash IMPROS. I was just hoping I could find some quick help on maybe I'm the idiot (quite possible lol).
    Resident Guru bored&stroked's Avatar
    Dec 2006
    Mesa AZ
    Quote Originally Posted by lawnkid14 View Post
    So you didn't even give them 24hrs to return the call?
    '96 Suuuperjet: 84mm 61x, ported, B-pipe, Dual 44's, Newmiller head 220psi w/girdle, Skat big hub, footholds, AMG green hell mango matte.
    '95 Raider 701: Fiberglass not SMC, Hydrotrailer hitch, ugly purple and yellow everywhere.
    PWCToday.com Is My Home Away From Home theVetteman3's Avatar
    Jul 2008
    Chicago / Portage, MI
    Impros does good work, but there can be a delay in their communication. If they got back even within two days I'd consider that good. Not an excuse, but they are busy and do excellent work. In the future just keep that time frame in mind.
    1985 JS550/800 "Pretty Red": Newmiller 800, Rhaas 750 pump conv. [56.3mph gps]
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    KP steering adaptor, Worx 228 intake, PWR ride plate [47.3mph gps]
    1987 WJ650:
    6M6, JD Intake Grate, 17/20, Coffmans Sizzler [48.5mph gps]
    1994 XiR: 830cc Superstock, PJS side draft, 13/18 swirl [53.7mph gps]
    1995 SJ MINT:
    Worx 205 intake [42.5mph gps]
    PWCToday Regular Sxipro750's Avatar
    Nov 2016
    Middletown NJ
    No issues with installing hooker on 650sx here. Nor any issues with communication Dave is always helpful and does top notch work Prob busy considering its mid season Make sure impeller is screwed on pump shaft completely And make sure pump is actually slid all the way on shaft
