2001 Seadoo GTX hull filling up with water
    May 2018
    Gulf Shores, AL
    Hey guys! My 2001 seadoo GTX is filling up with water while sitting in water, not running, I filled the hull up with some water and water was coming out of the bottom, black think on the bottom of the hull. I have taken a picture, is it normal for the water to come out there? I didnít see it coming from anywhere else. What was weird is one time, it did not fill up with water, but now as soon as I put the seadoo in water, it fills up fast. Any help would be appreciated. E82E820B-84D1-4F67-935A-DFD6F96C5A1E.jpeg
    Re: 2001 Seadoo GTX hull filling up with water
    Take the grey plastic pto cover off from behind the engine. You need to inspect the carbon ring.
    PWCToday Newbie Raggums's Avatar
    Jun 2018
    Northern Ontario
    ^ +1
    You need to pull your pump and drive shaft and pick up a carbon ring kit and you can change it out pretty easily.
