94 seadoo xp
Thread: 94 seadoo xp
    PWCToday Regular Seadoos9694's Avatar
    May 2018
    Kentucky
    94 seadoo xp
    I have a 94 seadoo xp and when i hook the battery up to it i get nothing no power any where I have cleaned the connections to the battery and also check the e box and changed the fuses that was blew any ideas?
    May 2018
    Kentucky
    Re: 94 seadoo xp
    Anyone have any idea? I took the e box apart and hooked the battery up and seems like the ground is good i arced the solenoid and it cranks
    May 2018
    Kentucky
    Re: 94 seadoo xp
    got a starter relay and it didnt seem to help anything
    Re: 94 seadoo xp
    Is the little red wire on the proper side of the solenoid? It needs to be on the battery side, not the starter side.
    May 2018
    Kentucky
    Re: 94 seadoo xp
    Im not sure it is but ill get a picture of it later and post it up
