FOR SALE: Kawasaki SXR 1100
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
    Resident Guru Dano 7's Avatar
    Nov 2003
    PA
    For Sale Kawasaki SXR 1100 ( $7000.00)
    Hull:
    * 2004 Kawasaki with clear title.
    * AC Racing Aluminum pole.
    * Pole spring tensioner block.
    * Blowsion 0 deg extended bars with cross bar pad
    * Tiny Tach.
    * ODI grips.
    * TBM adjustable steering plate.
    * Hot products heavy duty hood hooks
    * Handle bar bildge switch with Rule 500gph bildge
    * ZXI 1100 motor mounts
    * Modified stock hood for more air flow.
    * Blowsion carbon fiber dash.
    * JetTrim fiberglass rail caps & mat kit.
    * Pro Watercraft Racing ergo tray.
    * Pro Watercraft Racing race bumpers.
    * Pro Watercraft Racing front sponsons
    *Pro Watercraft Racing mid sponsons
    * Front spray deflector
    * IPD graphics
    Engine:
    * 1999 Kawasaki ZXI 1100 engine. ( approx 234hrs)
    * Stock porting lightly cleaned up.
    * 81.5 Wossnier pistons.
    * Stock head modified by Group K (140psi. 91 pump gas) with additional water outlets.
    * Rebuilt stock crankshaft by CrankWorks. ProX rods, Welded & trued.
    * Dried out ZXI 1100 exhaust.
    * Judge Racing rear water box.
    * Kawasaki stock flywheel.
    * .Pro Watercraft Racing exhaust support.
    * Kommander water outlet manifold.
    Ignition:
    * Stock ZXI 1100, air temp jumpered.
    * R&D Racing 5deg advance plate.
    * Stock ZXI 1100 ebox modified for 1100 swap
    * Judge Racing gas tank bracket for ebox.
    * New Napa AGM battery.
    Carbs/Intake:
    *(3) SXR 800 stock Mikuni BN 40-38
    * 1.5 SXR 800 intakes with crossovers blocked.
    * ADA angled reed spacers
    *(3) Stock ZXI 1100 reed cages and reeds
    *(3) K&N 3" coned flame arrestors with Outerwares covers
    *Remote Mikuni high volume fuel pump with GroupK air seperator.
    Pump & drive line
    *Stock 140mm SXR800 pump with duel cooling outlets 84/88 nozzles
    *16/24 Solas DF -5mm
    *TBM pump stuffer
    *TBM intake grate
    *JetDynamics Prototype T ride plate
    * TBM bulkhead support with aluminum spacer (Using STX 1100 drive shaft.)
    $7000.00
    Very reliable pump gas ski. 7300-7450 rpms approx 58-60mph.
    Additional 1100 spare engine and other parts available for additional cost.
    Ski is located approx 40mins from Pittsburgh, PA.
    PM me for more info.....
    Dano 7
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Nov 2003
    PA
    Re: FOR SALE: Kawasaki SXR 1100
    Pics on the way......
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Nov 2003
    PA
    Pics
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Nov 2003
    PA
    And more....
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Nov 2003
    PA
    I am selling to buy the new SXR 1500......
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Nov 2003
    PA
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Oct 2006
    under a ton of work
    very nice boat.keep it,the 1500 is not much fun.
    Nov 2003
    PA
    Quote Originally Posted by restosud View Post
    Thanks! I really do love my 1100 and want to keep it but, do not have enough room for 4 skis on trailer...At least that is what the wife says.....Do you own the 1500? Pros /Cons?
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Oct 2006
    under a ton of work
    yes,
    pro:reliable fast,hooks up,killer buoy chaser,almost perfect
    con: heavy ,big,not playful,no fun jumping in rough stuff,almost perfect
    Oct 2013
    funky town
    Resto, keep it down, bro. I want to see this boat first. Don't talk him into keeping it before I get a shot at it.
    Dano, 40 minutes which way from pittsburgh? What zip? Are you closer, or farther from N.Y.?
    I'm only here to make you mad
