1994 SL 750 Part out - Engine, Ebox parts, Pump Impeller, Carbs
    Jun 2009
    Syracuse, NY
    Title says it all!
    1994 SL 750:
    Engine - needs stator replaced - good compression all the way (around 120 or better) - don't have a flywheel remover, so flywheel and original stator still installed
    Pump/Impeller - OEM
    CDI and electrical connection board - untested due to stator not working - however, original owner bought this ebox to try and fix the ski until he found out it was stator.
    Carbs - OEM
    Jun 2009
    Syracuse, NY
    Re: 1994 SL 750 Part out - Engine, Ebox parts, Pump Impeller, Carbs
    Pics by request - also most is up on eBay - so that would be easier.
    Resident Guru DamageInc's Avatar
    Apr 2014
    Pismo
    Cdi for sale?
    96 xp stocker w/ the works
    96 xp stocker
    96 xp project
    92 X2 650/750 conv build
    90 JS440/650sx conversion
    04 YfZ450
    05 GSXR 1000
    Jun 2009
    Syracuse, NY
    CDI was bad.
    I have a big bag of BOLTS for this machine that is about to go on eBay - unless someone wants to make an offer on it first.
