2000 SUV Carb rebuild
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
    Jun 2018
    Eureka, Kansas
    Rebuilt carbs. Stock jetting, new 1.2 NS, Mikuni kits. Pop off set to 42 psi. Started like a champ. Noticed fuel dripping from the upper Venturi at idle on all three carbs. Bad NSís? Need more pop off?
    Frequent Poster Firebird!'s Avatar
    Apr 2006
    Lakeland, FL
    Re: 2000 SUV Carb rebuild
    You should have been able to see if the N/S we're bad or not during the pop-off test, when you rebuild the carbs, checked the operation and make sure the o-ring around the seat ain't leaking. So, if you did, than it is pop-off needs to be higher.
    Sent from my SM-N950U using Tapatalk
    '99 Yamaha SUV1200
    '02 Kawasaki Ninja ZX6R
    '12 BMW 650i Convertible
    '19 Honda Pilot Touring
    '19 Jayco Jayflight SLX 224bh travel trailer.
    Sold '12 Mercedes GL350 Diesel & '04 SL500, '99 Pontiac Firebird, '02 Ford Explorer Eddie Bauer, '09 GMC Acadia, '14 Acura MDX
    Its is normal for 1200NPV to drip fuel during idle.
    May 2007
    Don't listen to the self-proclaimed carb genius, he obviously has no clue when it comes to the 65u.
    They are not supposed to drip fuel at idle. They have 1.2 needle and seat to get your pop off pressure up in the 60/70 range for stock set up's. Check your check valves in the pump body the clear circular desk and look for creases. Only use genuine Mikuni rebuild kits and needle and seats.
    Do yourself a favor and do outside bills carb balance mod. You can find the how to thread on greenhulk site. The balance Mod is a must do imo. I personally own a 65u and have spent four years trying to tune it.
    Jun 2018
    Eureka, Kansas
    Everything I could find said pop off should be 38-42 so I went with it. Obviously that was wrong. I will go with the heavier spring and see what that does. Thanks!
    May 2007
    55 is The absolute lowest pop off you can have on the 65u even with the balance and other carb mods.
    Like I said I've spent four years tuning A 65u. I just change my set up tonight rotated my carbs 90į. If your butterfly shaft bushing's are not worn by now they soon will be. Since I had them apart put in new needle and seats one of my cylinders were dribbling. The way the stock Linkages pulll against the carburetors it's very difficult to get them in sync group K talks about this on their website. Plus it wears out butterfly shaft bushings quickly. IMG_2199.JPG
    May 2007
    May 2007
    May 2007
    Stock set up.
    Quote Originally Posted by driftmaster View Post
    Yeah keep trying sooner or later you will get it.
    I dont think I have ever seen a 65U that didnt dribble fuel at idle. They shake so bad at idle its gonna happen as long as it runs ok I wouldnt worry about it.
    Drift has spent 4 years trying to tune his so that tells you what kind of tech he is. Fing idiot.
