Only stays running with choke partially closed
Results 1 to 6 of 6
    May 2005
    Right here
    Just picked up an FX1 today and even after it warms up it won't stay running(or stumbles and dies) if I don't keep the choke pulled out about 3/8 of an inch. What would cause this? Plus every time I wipe out and it turns on its side a bit, it croaks.
    May 2005
    Right here
    Re: Only stays running with choke partially closed
    fresh bump
    Mar 2009
    Fort myers Fl
    Itís running lean if the choke helps it. Rebuild your carbs.
    May 2005
    Right here
    Quote Originally Posted by Couchrider View Post
    It’s running lean if the choke helps it. Rebuild your carbs.
    Could it just be a gunked up low speed jet?
    Post falls Idaho
    Check compression , pull carb , check internal filter , plugged with hair balls , rebuild carb , check for cracked fuel lines at selector valve and if has primer kit check supply hose for cracks
    May 2005
    Right here
    Done. Still ain't working
