1993 GTX Fuel Sender Question
Results 1 to 2 of 2
    Jul 2016
    North Carolina
    Hey everyone! Was hoping to get some knowledge on this common subject. Picked up a low hour ski from the original owner who had given up trying to get this thing to start. Turns out they had a faulty solenoid, they wired the new one wrong, and burned up the MPEM trying to jump the engine off. Anyway I've run into issues with the fuel gauge; reads 3/4 to full regardless of tank levels. When I disconnect the sender the gauge reads empty, when I jump the harness wires it reads full. When I first got it in the water the gauge read full regardless until a few hours later; after going from full to a 1/4 tank the gauge would sit on 3/4. What do you guys think? Float stuck/broken and needs a rebuild?
    Thanks for the help!
    May 2009
    South Carolina
    Re: 1993 GTX Fuel Sender Question
    Reading should be from 90 ohms to about Zero when checking with a multimeter across the 2 leads coming out of the fuel baffle. Sometime the float can stick in the older style baffles if you are using a new float but after riding they usually come loose. This could stick at 3/4 tank level.
    The float has a magnet on it which activates magnetic switches on the circuit card inside the baffle and brings resistance in and out as you float goes up and down inside the baffle. Two common problems with these are: the old floats saturate with gas and sink and on some of the soft floats(like used in a 93 GTX) the magnets fall out of the float into the bottom of the tank, or the on board fuse blows and then you have no actual reading (reads full).
    Think Big!!
