how bench test vts module
    May 2010
    omaha ne
    #1
    i have a bunch of them and need to go through and see what is good and what is not i want to hook up my jumper box to each and run it in and out tring to look it up to see what wires i need to be connected to and to jumper to run it
    paypal = shagy959@aol.com text 4027407749
    Re: how bench test vts module
    May 2010
    omaha ne
    I don't want to have to ohm out every wire I would like to hook up 12 v and test it that way
    Frequent Poster Keno's Avatar
    Sep 2010
    Kansas
    Well, you can figure out the wiring from his link or a schematic. But I'll help you out.
    Red/Purple/White to 7.5 amp fuse then to +
    Black To -
    Purple/White to 15 amp fuse then to +
    Green/white bridged to black = down
    Blue/white bridged to black = Up
    Brown/black and Brown/White to VTS gauge
    Blue/orange and Green/Orange to VTS motor
    If I was setting up a rig for testing, I would use Reset-able fuses, a current limiting power supply or an automotive 12 volt headlight bulb in line with one of the power wires as a current limiting device.
    96 xp - not stock
    RCW Brawler
    Braap!!
