94 seadoo xp boring
Results 1 to 10 of 14
    PWCToday Regular Seadoos9694's Avatar
    May 2018
    Kentucky
    94 seadoo xp boring
    what performance upgrades can be done to my 94 rotax 650 motor to increase proformance and power
    Oct 2012
    florida
    Re: 94 seadoo xp boring
    leave it alone its not worth it
    95 hx 787
    96 xp with miller motor
    92 gmc typhoon and 99 frc vette
    Sell it and get yourself a '96xp or '97 up spx.
    May 2018
    Kentucky
    I have 2 96 xps 2 94 xps and a 96 gsx
    but thanks for the advice
    Jun 2011
    Modify the XP’s and/or the GSX and keep the ‘94 XP for cruising or friends to ride...
    What would Chuck Norris do?
    OK, you have the fun playful stuff and you're bored........time for a standup my friend!
    May 2018
    Kentucky
    i was going to mod the gsx but idk what to do to it whats good to do to ti i no its probably faster then the 94 xps with the 650s right
    Quote Originally Posted by Seadoos9694 View Post
    You own them but dont know how fast they are ???
    May 2018
    Kentucky
    Well im pretty sure the 96 xp is the fastest i got followed by the 96 gsx then the xp
    Jun 2011
    Correct. The ‘96 XP & ‘96 GSX will beat your ‘94 XP with no problems.
    I have a modded ‘96 GSX w/Factory Pipe Spec 2(Rec Chamber), BuckShot 44mm carbs, BuckShot Head w/43cc domes, Jetinetics aluminum flywheel, BuckShot oil injection block off plate, Skat Trak 17/24B Swirl impeller, stock 140mm brass pump, R&D 85mm/88mm (Exit/Steering nozzles), R&D AquaVein intake grate, Beach House sponsons, HydroTurf mats, aluminum trigger throttle, JetTrim custom seat cover, AGM battery, stock timing, non ported engine that runs all day everyday without issue. Good rough water ski(I ride 95% ocean), long fuel range(15 gal. tank), decent enough handling and a true 2 seater boat. Very stable with just a single rider. But also very stable with 2-Up riding.
    You could modify the ‘96 XP just the same because they share the same motor. So pick your poison.
