Plugs and piston tops black - Page 2
Results 11 to 13 of 13
    Resident Guru mandriva's Avatar
    Sep 2009
    montreal,quebec
    Re: Plugs and piston tops black
    Damage inc, don’t worry about this jetting!use that!
    Pop off is lower =more gas all rpm
    Rossier 7250 rpm
    110 mid pipe/200 stinger
    185 psi/Head 41cc/43squish
    Solas concord 15/23
    Resident Guru DamageInc's Avatar
    Apr 2014
    Pismo
    Don't recall exactly what impeller I'm using, but I wanna say it's around a 17/22 or 23. I could be wrong tho. I pulled the Jetworks and left the 150 in the stinger.
    Took it out yesterday with my x2, and found a not blowout on the mid pipe coupler from that fkn clogged jet.
    Otherwise, this setup has run really well for two seasons now. I've had the low speed screw out at 1 1/2 but I think 1 1/4 will be better.
    7190 is best I've seen
    96 xp stocker w/ the works
    96 xp stocker
    96 xp project
    92 X2 650/750 conv build
    90 JS440/650sx conversion
    04 YfZ450
    05 GSXR 1000
    Sep 2009
    montreal,quebec
    Remove the jetwork=garbage for rossier ,i loss bottom end
    200 stinger
    115 mid pipe
    Stak trak 12/22 swirl
    Squish 45
    The sweet spot with this pipe is 7200/7250 rpm
    Rossier 7250 rpm
    Solas concord 15/23
