2001 GTX DI water leak
Results 1 to 10 of 10
    May 2018
    Surprise, AZ
    I have found a lot of water in the hull and putting it on the trailer I noticed that it was coming from what I think is the compressor silencer that is mounted on the left side of the jet pump transom, it has what looks like a big nut and a hole without threads in it, the hoses look like they are good going to it.
    Any thoughts?
    May 2018
    Surprise, AZ
    Re: 2001 GTX DI water leak
    And I replaced the carbon seal because I thought that is what was leaking.
    May 2009
    South Carolina
    #1 unknown reason for water in the hull is the exhaust water port bung plugs. They corrode through at the edges of the weld and leak.
    Think Big!!
    May 2018
    Surprise, AZ
    That is where it looks like it is coming in at, at least that corner. Are they replaceable and do you know where I can find part numbers or the exact name of it, I searched for them and came up empty.
    PA
    You won't find that as a separate part; it is sold as an assembly with the pipe. A good welding shop should be able to cut a few new ones and install. Do them all, so you don't have to do this twice. If they can't/won't make the parts, then you don't want to business with them.
    May 2018
    Surprise, AZ
    I found that it is coming thru the fitting where the cable to the speedometer comes thru the rear transom.
    PWCToday Guru 1983's Avatar
    Jul 2014
    North Carolina
    Glad you found it!
    May 2018
    Surprise, AZ
    Any chance do you know the part number for the thru hull connecter for the speedo? I've looked and can't find it, I may be looking at the wrong thing but it looks like there is the sensor and the paddle wheel and then and thru hull connecter then a cable from that to the gauge cluster.
    Jul 2014
    North Carolina
    https://www.seadoopartshouse.com/oem...540-5541-parts
    It will be somewhere on that link, I'm on phone so can't see full parts diagram easily
    May 2018
    Surprise, AZ
    Quote Originally Posted by 1983 View Post
    Thank you, that helped.
