1995 speedster to much fuel.
Results 1 to 10 of 12
    May 2018
    TX
    I recently bought a 1995 seadoo speedster with the twin 657x motors. It was non running when I bought it once I repaired the mpem took it out to the lake it ran good and idle all day but as soon as I throttle it up it would slowly die out as if out of fuel. It was happening with both motors but would always restart after dying. Took it home removed carbs and cleaned/checked everything to avoid a long story I had to replace the carbs on one engine. The engine with the new to me carbs fires right up but the old carbs I cleaned keep having a problem of when I try to start the engine it just keeps spitting fuel out the carbs. I have it all set per manual. Tested the pop off pressure and it's set to 21 so I'm not sure what else it could be. Also all fuel lines have been replaced.
    Mar 2009
    Fort myers Fl
    Re: 1995 speedster to much fuel.
    Does the engine with new to you carbs run properly now? If your dumping fuel, I think that points to needle and seat, did you rebuild with OEM parts?
    Oct 2017
    Wyo
    Whose carb kits did you use.
    May 2018
    TX
    I have not fully rebuild them just took apart/inspected and checked the seal on the needle and seat and pop off pressure.
    Mar 2009
    Fort myers Fl
    Id start with a genuine rebuild kit, maybe even go as far as a harbor freight ultrasonic dip and clean the carbs
    Mar 2009
    Fort myers Fl
    Do not put the pump diaphragm piece if you do get Ultrasonic
    May 2018
    TX
    Well got the carbs all worked out or what I thought they have all factory mikuni parts in the both engines where running great took it out to the lake it still idles all day long and can putt around under 3k rpms all day as soon as you rev up it holds 7k rpms for about 30 seconds then dies and even the engine with the new carbs does the same. Before I put it back together I blew back through the fuel lines to see if anything was plugged but could hear bubbles in the tank. Am I missing anything?
    Its starving for fuel...
    Remove fuel selector valves & run a line from tank to fuel filter then filter to carbs.
    May 2018
    TX
    Is that a common problem with these?
    Very They did away with those valves around 96......
