95 SPX wont run under load after carb rebuild
Results 1 to 10 of 10
    May 2008
    Munster,indiana
    Just recently rebuild the carbs on my 95 spx, genuine mikuni kits with brand new needles and seats. Also replaced all of the fuel lines and even pulled out the fuel selector to clean it before reinstalling everything. The ski will start up and idle fine until the hose is turned on and then it bogs and dies under load unless there is starting fluid being introduced. Not sure if the rotary valve needs to be checked or if water is seeping into the cylinders.
    Re: 95 SPX wont run under load after carb rebuild
    If this is on the trailer then the impeller is not in the water and there is no load. After it dies, pull the spark plugs and look for water droplets.
    May 2008
    Munster,indiana
    Correct it's on the trailer and once the hose is turned fully on it will die during idle. Is it more common to get a hairline crack in the jug or does the base gasket fail more often?
    Jun 2011
    Were the plugs checked for water droplets?
    A hair line crack would happen if the motor was overheated. I’ve never encountered a torn base gasket. But others may have.
    What would Chuck Norris do?
    May 2008
    Munster,indiana
    The plugs were a tad bit wet but with oil.
    Cypress, TX
    I've heard that the plastic Seadoo Fuel Tank Pick-Up Tubes tend to crack and leak...maybe take a look and see.
    Jun 2011
    Quote Originally Posted by edobi21 View Post
    Sounds like a rich condition. You’ll need to set the idle speed to spec at 3,000 rpm on the trailer and 1,500 rpms with the pump loaded in the water. You’ll need to adjust the low speed screws in at 1/8 turns until you can achieve a crisp & clean pull of the throttle while adjusting the idle speed to 1,500 rpms each time you make an adjustment to the screws. Change those plugs to new BR8ES plugs gapped at 0.20” - 0.24” and adjust from there. It’s best to have the pump in the water when adjusting the carbs.
    Is this ski stock or modded in any way?
    May 2008
    Munster,indiana
    No the ski is 100% stock and the low speed was set to 1-1/8 per the manual and plugs gapped at .24"
    May 2009
    South Carolina
    You checked carb pop off and verified that you have fuel flow through both carbs (return orifice in carbs is clear). Sounds like a fuel issue.
    I'm going to sound like a broken record but when you do carb and fuel line work you need to prime and pressure test the fuel system. That way you know that most everything is working like it should, you have fuel flow, and you have no leaks. Leaking fuel into a jet ski hull is not a good thing even with flame arrestors.
    Think Big!!
    May 2008
    Munster,indiana
    The ski is at the lake house, but im going to pull the return line of the carbs and make sure they're both getting enough fuel next weekend when i'm up.
