1994 seadoo xp help and 1996 seadoo xp - Page 2
Results 11 to 20 of 56
    PWCToday Regular Seadoos9694's Avatar
    May 2018
    Kentucky
    Re: 1994 seadoo xp help and 1996 seadoo xp
    yeah the black gasket is poping out but out of the vts not the speedo
    Dec 2006
    Wrong gasket. The one I'm talking about is under the black metal band that keeps the clear lens face attached to the black plastic gauge housing.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    96XP Wake-jumping demon #1
    96XP Wake-jumping demon #2
    May 2018
    Kentucky
    Do i need to take it off and see im more worried about the vts and gas one then how fast im going
    May 2018
    Kentucky
    Ok so i kinda figured something out when i hook the vts up and try to use the vts it just clicks and then it blows the 7.5 fuse any idea why ? but the beep goes away when the vts isnt on there
    May 2018
    Kentucky
    also figured out my vts works and the motor works but for some reason when you go down or up with the vts gets all the way either way its gets tight either way you go then it gets so tight it cant turn the other way is my motor weak or what is it?
    Dec 2006
    The VTS module has failed like I said. The limit switches (glass reeds) have failed. So the motor keeps traveling until it physically stops and not because the Reed switch kills the power to the motor when it travels to a certain point.
    May 2018
    Kentucky
    how do i fix this
    May 2018
    Kentucky
    Yeah it travels until it cant go and then blows the fuse
    Dec 2006
    Buy a VTS module. That's the correct fix. It's too time consuming and tedious for the average person to cut out the potting compound and repair the reeds. Any kind of solvent that will disolve the epoxy is expensive and may destroy what you are trying to save in the process.
    May 2018
    Kentucky
    so i have to buy the whole thing huh
