I have a 1995 WaveRaider 1100. Would it be recommeneded to change out all the fuel lines in the ski itself? Nothing leaks today, and everything works.
Change fuel lines or not?
Collapse
X
Re: Change fuel lines or not?
I rarely ever change out Yamaha oem lines. They are very high quality.http://www.facebook.com/twinlakesjetskirepair
Obviously a lot of you don't live in dry hot climates. Yes, here in AZ we change fuel lines out. They eventually become hard as a rock and brittle.'96 Suuuperjet: 84mm 61x, ported, B-pipe, Dual 44's, Newmiller head 220psi w/girdle, Skat big hub, footholds, AMG green hell mango matte.
Comment
Comment
