Results 1 to 10 of 10
    Jul 2004
    Texas
    RAVE valve adjustment ...?
    I read somewhere, that you can adjust the RAVE valves ... How?
    I loosened the plastic cap screws under the spring slightly, but that didn't do a thing ... any suggestions?
    There are 3 truths:
    1. Life ain\'t fair - live with it.
    2. You CAN have it all - just not all at once.
    3. Men are from Mars - and I still don\'t have a clue where women are from ...
    Murfs66
    Guest
    Hauker , To my understanding there are 2 sets of rave valve on the ski. One for the bottom end and one for the top end. the head and the exhaust. I believe the exhaust rave controls how much water is dumped into your exhaust and the other controls back pressure. You adjust one set the oposite of the other to achieve the performance your looking for. For instance all the way down on one and all the way up on the other and slowly screw them in the oposite direction after test runs to achieve max performance......anyone else,,,or am I wrong? I think thats just the start of it....
    Murfs66
    Guest
    Oh ya dont leave them fully up or down at any point just use this as a starting point......
    Jul 2004
    Texas
    I think I just had a revellation ... I didn't try to adjust the blue plastic screws on top of the dome, but the black screw-in valves with the rubber fitting underneath the spring ... duh.
    Guess that wasn't all to smart
    There are 3 truths:
    PWCToday.com Is My Home Away From Home Rudedog's Avatar
    Nov 2003
    At home. Why, where are you ???
    To my understanding, the rave valves are the ones ON the cylinders on the 800 and 951 models.
    By adjusting them way out you will open the valve sooner and allow exhuast flow quicker.
    If you adjust them way in, they will open later as the rpm's increase.
    I ran my 800 valves out when I moded my xp, allowing the valves to open sooner decrasing the amount of rpm needed to open them.
    If I were you, I would work with them in incriments and get the best result for your set up.
    Good luck
    Rudedog
    The faster you go, the faster you wanna go. RPM
    Bomber Eyewear, Impros, KMG
    I dream skis TeamShark's Avatar
    Feb 2005
    Dallas, Texas
    Rudedog is right. Based on others input, I am running is old ski with the valves out. Hey, remember that starting problem once it is hot situation. Under this same forum Waterworxs indicates that it is the rave valve clearance which is off. I have recently changed the needle/seat and have new jets and also increased the spring from a 65 to 95. My new pop off is about 23. I have lost the huge hisitation off the line and have not tried letting it sit for 30 minutes once I run it to see if she cranks over with push of the start button. What do you think about the rave valve clearance he says that is the cure to hard starts.
    Seadoo Novice "Limited" R/A 800, "Stock" R/A 1200, TEAM SHARK #800, 2005 Hot Water Tour-3rd. Place Overall-Amateur Limited 800, 2005 APBA Nationals "Amateur Limited 800" 5th place.
    Sponsors: Elite Performance, Skat-Trak, Slippery, UMI Racing, M2R Helmets, Spy Optics, Fuel Clothing, Amsoil, Hot Products, LA Sleeve, Hydro Turf, SixSixOne, my job.
    Nov 2003
    Thats very possible. Try another set and see what happens.
    When I think back, I don't think I ever changed them.
    Though I did put a rebuild kit in (ie.spring, rubber,and the seals).
    L8TR
    Rudedog
    Feb 2005
    Dallas, Texas
    Sorry. I meant to say Rotary Valve Clearance, but now Waterworkx says that he has never heard about this problem in the 800 motor, just in the smaller motors. Anyway, I hope that my new jetting, springs, needle sets works for my hard "hot" starts.
    NPR
    Rave valves have nothing to do with starting.
    I dream skis njrealtor55's Avatar
    Nov 2002
    Flemington, NJ
    intake to rotary valve clearance should be measured with soldier. the proceedure is in the manual. performe with no gasket on the intake manifold & no lockwashers on the intake manifold bolts. the measurement should be 12 thou of an inch +/- 2 thous. I set our 800's to 11 thous of an inch so we have lots of time before excessive wear occurs.
    too much space between the rotary valve and the intake manifold will make the ski very hard to start in the water. if the measurement is more than 14 thous of an inch get it milled. don't forget if the milling is more than 3 thous you have to relieve the o-ring cutout as well.
    now for rave valves...
    if you unscrew the adjusters on the caps the valves on the cyl will open sooner, but the motor will produce less bottom end. if you screw them in more - you will loose top end. we leave our stock boat adjusters flush with the cap. our raceboats run larger valves and make much more HP, so the screws are backed out slightly...
    i have heard that screwing in the adjuster on the waterbox valve will give more power, but i have never played with that setting before... we hard jet our raceboats, and i just keep the stocker flush with the cap to avoid melting the cross-over hose.
    hope that helped.
    Jason
    www.Purrperformance.com - for all your GP Class 951 SX-R needs!
    www.macsboost.com - for stinkin fast honda's
