Aquatrax speedometer stuck on 0
Results 1 to 8 of 8
    Mar 2018
    Louisiana
    My speedometer has been stuck at 0 since I bought it, and ideas or directions to go in to get it working!?
    2007 t3 turbo
    Thanks!
    Dec 2005
    Page, Az
    Re: Aquatrax speedometer stuck on 0
    go to the rear of the ski down on the ride plate . there is a trigger wheel on the right side of the steering nozzle. make sure that the wheel is there. If it is there make sure that it spins free. then look in the little tunnel in front of the wheel to make sure there isn't a small pebble or rock blocking the passage.
    Not sure if it's like my 03 F12x BUT when you put in the water stator (jet pump), the wire that runs to the wheel at the rear of the ski for the speedometer can easily get between the pump housing and get pinched , might make sure it's free.
    May 2018
    Miami
    Did you get yours fixed? I am trying to do mine now. My wire was actually crushed when they mounted the pump back in ski.
    Tom
    You'll probably have to get a new wire , mine wasn't broke, I noticed it when it wouldn't seat evenly and pulled it out.
    May 2018
    Miami
    I ordered the wire. But I have no idea where it hooks to. The old one was jus sitting where it attaches thru the hull. Not sure if it should have a lead coming out of gauge cluster or from the battery somewhere. Going to try and locate a shop manual for this.
    Tom
    I just got off a cruise from Mexico, I'll look it up when I get home tonight.
    Apr 2018
    PA
    Its the yellow connector:
