Tech Article : Kaw 650/750/800 Cooling Upgrade
    Tech Guru Resident Guru
    Feb 2002
    Fort Mohave, AZ
    We are constantly swamped with Kaw 650/750/800 owners wanting to upgrade their cooling systems (1/2” line … dual water-line, etc). We let them know there is one very simple upgrade that every 650/750/800 owner can do that makes a BIG improvement in cooling. The 650/750/800 cylinders have 3 water jacket entries fed by the water jackets in the exhaust manifold. Unfortunately the lower water jacket entry slot has no connection to the rest of the cooling system and it leads nowhere (which means NO coolant flows through it). By simply drilling a 1/8” hole through the connecting passage, you turn a useless (land locked) cooling passage into an active part of the cooling system. The added reduction in temps around the exhaust port are significant. This cooling mod is a standard addition to all the ported cylinders we do in house at Group K….. It’s easy, and it works damn good …. Your welcome 
    Unless otherwise stated, responses to all forum posts are based on my personal experiences working within the PWC industry, and developing high performance PWCs since 1987.
    www.groupk.com
    PWCToday.com Is My Home Away From Home freekstyle's Avatar
    Aug 2007
    Re: Tech Article : Kaw 650/750/800 Cooling Upgrade
    Nice! Thanks for the tip.
    PWCToday.com Is My Home Away From Home Cleatusjo's Avatar
    Aug 2014
    Chesapeake Bay, Anne Arundel co.
    Great mod, and can be performed in the ski.
    '94 Kawi TS
    2002 Kawi STX-R
    too much to list
    Resident Guru Dano 7's Avatar
    Nov 2003
    PA
    Thanks for sharing!
    96/99 ZXI 1100 - Parting out. Have engine & ebox and misc stuff. No hull. PM me for other needed items.
    02 SXI PRO
    04 SXR 800
    19 SXR 1500
    17 YZ 250X
    Feb 2016
    New Jersey
    Great tip - Thank you. Just one hole per cylinder, or should I drill holes on each end of the lower water jacket entry slot?
