97 GTX just died and won't crank over.
Results 1 to 10 of 18
    Sep 2016
    orlando
    Hello all, I have a 97 GTX that I am trying to revive. I got it running the other day with a brand new battery in it. Ran fine around the lake for about an hour. Needed to replace the wear ring. Replaced it, and went to test ride this morning. Ski started fine and got me half way across the lake and just shut off. I was able to restart and it ran about 100 feet and just died. Then would not crank over again. The only warning I have at the time is 12v low. I swam the ski back to shore and brought home. Put meter on battery, and it is 12.16v. Any ideas what might cause this. I know that the battery needs to be sufficiently charged to produce spark, but shouldn't this be high enough? Thoughts?
    Sep 2012
    Huntsville, AL
    Re: 97 GTX just died and won't crank over.
    Sounds like its not charging the battery
    Jul 2014
    mid tn
    battery at 12.6 is good on voltage. does it crank and not start? if it cranks then you need to run down the usual check list. check compression? have the fuel lines been changed from the grey ones? has the fuel cut off selector been cleaned? is the gas fresh in it? has carbs been cleaned and filters changed?
    Sep 2016
    orlando
    Yes, all other issues have been resolved I believe. Carbs redone, all new fuel lines, new coil and plugs. I am pretty sure it is a electrical issue. It just shut off, as if I pulled the lanyard. No sputtering etc. Then would not crank. I just took it off the charger and it fired right off. Was trying to check rectifier, but not sure what to look for. The voltage at the battery with the engine running is still in the 12.5 range. Shouldn't it be around 14 or so?
    Jul 2014
    mid tn
    Quote Originally Posted by b8man View Post
    yes. when running it should be at least above 13 and with good battery could go over 14 but at least above 13 will let you know it is charging. I am not sure what to check for it not charging though. hopefully someone else will comment a suggestion. is all fuses good? is the ground to engine good? really good?
    Sep 2016
    orlando
    I believe it is as good as can be...I am hoping someone can point me in the right direction. I appreciate all the help so far. I am so frustrated right now, this ski is possessed.lol
    When the DESS post goes bad they will randomly shut off like that.
    Sep 2008
    The flakka capitol of Florida
    The rectifier is bad
    PA
    A good battery will sustain a 12.6 volt level (6 cells x 2.1 volts per cell) with a moderate load applied. To charge a battery (that is, to have the flow of current into it), you have to have higher voltage than 12.6 (or what ever the battery is at when you start). At 12.5, you aren't charging. Your shut-off likely occurred because you dropped below the MPEM low voltage limit. Cars will do the same thing. Its not like the old days. Like kcr said, I'd suspect the rectifier first, as they seem to be a bit tender in some models. Hopefully yours is not built into the MPEM. After that, broken wire from vibration, shorted/wet coil, metal fragments in the coil area. See if you can locate a manual for your boat and do the output test of the three phase coil. If the coils have a balanced output, and you can prove continuity through the wiring, then you're left with the regulator as the culprit.
    Sep 2016
    orlando
    Awesome...thx for the info...I have a brand new coil with plugs and wires. I was able to find a video about testing the magneto with an ohms test and that seems ok. Therefore I have ordered a new rectifier. Hopefully this does the trick. Will update once installed. Thx again
