Priming fuel on 93 kawasaki 750
    Jan 2018
    Albuquerque
    I recently pulled motor and replaced starter, bendix, rebuilt carbs and replaced all fuel lines. Now im trying to start it and fuel wont go to carbs. It will start and run if i slowly spray mixed fuel into carbs. I did this for about 30 min and it still wont get fuel to carbs! I rechecked my fuel lines and they are all routed as they where when i took them off (i took pictures and replaced them one by one so i didnt mix anything up). What else can i do? This is getting frustrating! The only thing i did different was add an inline fuel filter since it didnt have one. I dont think this would matter though would it? It has yhe dual kelhein carbs if this helps.
    SE MI
    Re: Priming fuel on 93 kawasaki 750
    Ok, I apologize for this suggestion but is the fuel pet**** on?
    Jan 2018
    Albuquerque
    Yes it is. I actually double checked that. I wasnt sure at first myself!
    Jan 2018
    Albuquerque
    I got it. Dumb me had 2 of the fuel lines backwards! I double checked it with my pictures and there it was!
    Top Dog TMali's Avatar
    Mar 2011
    Brooklyn Center, MN
    Ive done something stupid like this before
    Is the "on" and "reserve" lines hooked up to the correct fuel tank pick up? Ive had mine hooked to the return line before
