Js550 rebuild its alive
Results 1 to 9 of 9
    Oct 2017
    connecticut
    Ok I got the js550 for $100 it hasn't run from what the guy said for at least 10 years
    Checked the compression mag 140 pto 142
    I rebuilt the bn38 and changed all the fuel lines.
    Sprayed fogging oil in the cylinders and it started up it smokes like crazy shut it down let it cool and started it again adjusted the carb this time let it cool again
    Started a third time gave it mid throttle and this green stuff was coming out of the exhaust
    is it crap in the exhaust system ???
    PWCToday Newbie Galmo's Avatar
    Feb 2018
    Concord, CA
    Re: Js550 rebuild its alive
    Could be gunk that was sitting in the water box.
    Oct 2017
    connecticut
    Quote Originally Posted by Galmo View Post
    at first it was just black oil then after revving it this crap came out I'm going to take out the water box and try and clean how would I do that??
    Aug 2011
    Austin, Texas, USA
    Just run it. It will clear out rather quickly.
    Riding mostly Lake Austin
    Its residual water mixed with oil that was sitting in the waterbox. Nothing to worry about.
    Oct 2017
    connecticut
    would that explain why its smoking so much also?
    Feb 2018
    Concord, CA
    Yeah like said above nothing to pull the water box out for. Just run it clean
    Yep.
    Frequent Poster Riverrat650sx's Avatar
    Jan 2011
    Tuscaloosa,AL
    The fogging oil will make it smoke like crazy too.
