Widening 550sx Tray
Results 1 to 10 of 20
    PWCToday Newbie Galmo's Avatar
    Feb 2018
    Concord, CA
    Widening 550sx Tray
    Hey guys. This is my first post and firstbuild. Also first time doing some glass work so critiquing is very welcome. I get a little advice here and there from Posts and a buddy that has limited experience with fiberglass. I'm going to shorten the rails about 4in to give myself a little bit of a flat deck on the back. And widen the tray about 2 in on either side. I don't think I'm going to Glass footholds in. Probably do some foot straps or lifter blocks.
    Here's what we start with. I already removed the side rail mats.
    Here's the plan as per Sharpie
    Mar 2005
    Santa Barbara, Ca.
    Re: Widening 550sx Tray
    Make sure you use epoxy based resin on the hull or she no sticky
    Good luck!
    Feb 2018
    Concord, CA
    Everyone has been telling me to use poly resin. Because that's what the manufacturer used.
    Top Dog
    Oct 2006
    under a ton of work
    nope.epoxy only as bruceinsb said.
    Feb 2018
    Concord, CA
    Ok thanks for the heads up.
    PWCToday Regular jlunde's Avatar
    May 2017
    vancouver canada
    550s are SMC fiberglass which is resin based if I'm not mistaken....buy SMC resin
    Feb 2018
    Concord, CA
    Cut and refoamed.
    Now a little filler work and sanding and I think I'm ready for glass.
    Feb 2018
    Concord, CA
    Okay I'll look into that also. I'll go talk to the guys down at Tap Plastic. They've got a lot of fiberglassing supplies
    Feb 2018
    Concord, CA
    A little filler to smooth everything out
    Think I'm ready for some glass
    Feb 2018
    Concord, CA
    Also any good ideas for mounting my extinguisher else where? I was thinking somthing like this61IW-GFeLSL._SL1500_.jpg
    Rivited inside the hood maybe?
