Results 1 to 6 of 6
    Oct 2016
    Washington D.C.
    Help Identifying Mystery Seadoo Impeller
    Hi,
    Trying to identify a stainless seadoo impeller. I plan to make a pitch gauge and measure pitch. Was wondering if anyone has seen one of these before? It came out of an early 90's ski, it is stainless and pretty heavy. The only number cast into the impeller is "9" Anyone?
    Resident Guru Bionic racing's Avatar
    Idaho/California
    Re: Help Identifying Mystery Seadoo Impeller
    9 or 6 ? Old scat 19 or 16 , early ones did not have the swirl finish put on them as the newer ones
    Early 90s would have been 587 powered. Thinking that must be a 16 pitch.
    Feb 2002
    Vancouver, BC Canada
    It's aluminum, toss it. There was no 16 pitch, only 19.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Oct 2016
    Washington D.C.
    Chester
    NO, It's stainless...like I said...lol
    It also looks to be variable pitch....
    Feb 2002
    OK, then it's a 19 straight pitch.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
