    Mar 2009
    Fort myers Fl
    Needle bearing question 951.
    I wanted to use the oem loose needle bearings as they have more bearing to surface and I read that a few race engine builders use the loose bearings as well.
    I just looked at my local seadoo dealer and the new part number for the needle bearings has been replaced with a caged bearing, no needles exposed on the outside of the bearing only the inside.
    Part number is 420832552 superseded 290832550
    This is different then the other caged bearings I see for sale.
    Whatís the best route here?
    Mar 2009
    Fort myers Fl
    Re: Needle bearing question 951.
    Hmm is this just a container that holds the individual needles? Remove from this and install?
    Feb 2002
    Vancouver, BC Canada
    Those are not caged. They are still loose. Those plastic parts hold them together during installation and get discarded.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Mar 2009
    Fort myers Fl
    Ok I saw a random pic and saw one with a pin sticking out the side, thatís how I got to that conclusion. Thanks for the confirmation
