XL1200 1999, Do u think this seizure is possible?
    Frequent Poster gazza2010au's Avatar
    Jun 2010
    Australia
    Hey guys i just picked up this ski pictured the bloke i bought it from had semi dismantled it and took a picture of the bendix thru the starter motor hole and there were a few missing teeth, the motor is locked up, do u think its possible for those teeth to have gotten into the flywheel and is binding the stator and flywheel?
    Re: XL1200 1999, Do u think this seizure is possible?
    Yes on teeth jumping around inside cover but no its either the pump locked up or the motor.
    Jun 2010
    Australia
    Sure was the motor mate check out the damage ouch any ideas how to lift the cylinders off? i am soaking the piston and rings with XPS seadoo storage oil
    i am praying those two rusty cylinders are soaking in oil down in the crankcase
    Jun 2010
    Australia
    I ruin one piston but it was the only way of salvaging the cylinder and crank, crank turns over but front and middle piston and little end bearings are seized i'm about to press the pins out of the pistons i really hope i can salvage the crank and that the rods little end will only need a hone fingers crossed
    Top Dog orangefinger's Avatar
    May 2006
    Reno,NV
    i am speechless.....
    u need to pull that engine and completely disassemble...
    ....still speechless
    94 Blaster "KAW 1100cc"
    650 SC
    Jun 2010
    Australia
    Quote Originally Posted by orangefinger View Post
    Oldmate that i bought the jetski off last night insist the water entry was from him not being able to flush the motor on the last run, i politely told him the probable cause would have been uneven cylinder head and or warpage of the cylinder headplus incorrect torque of the head bolts
    the last owner had carried out the new top end including spending AUD$700 on a new No:3 cylinder and replacing all 3 pistons
    it had 5 hours work on the new top end
    once i get the piston pins out and look at the little end rod section i will see if its worthy removing the entire motor, i know pulling the lot out and flushing the whole lot in petrol is the best way but i am between moving houses and i have a lot of stuff to move once we get the new house i dont need the drama of adding another 150kg motor and all its bits to the move
    Jun 2010
    Australia
    I have made the decision this whole engine is coming out i am purchasing a 6 ton shop press this afternoon to remove those pistons, yesterday i tried removing the front No:1 piston using a 17mm bolt which has a head diameter of 21mm the piston pin is 22mm diameter so a perfect fit i put the impact gun on the bolt and only managed to move the piston pin 1mm i think when the motor hydro locked the No:1 No:2 piston pins bent plus the salt water intrusion rusted the bearings
    i just called my crankshaft specialist its going to cost bare minimum AUD$300 that's around USD$220 to disassemble and reassemble the crankshaft i am just hopping its not a genuine non rebuildable crankshaft because they charge AUD$150 per web journal machining to turn it into a rebuildable OEM yamaha crankshaft
    what happens next i will remove engine mounting bolt and hook up the engine hoist and pull the motor out, once i split the cases that crankshaft is getting a good bath and blow with the compressor to clean all the bearings to minimize the rebuild cost
