Supercharger paint removal
Results 1 to 2 of 2
    Sep 2008
    The flakka capitol of Florida
    How in the utter heII do you get this stuff off? Paint remover helps, but leaves enough on that it has to be sandblasted(or course it's in the nooks where a wire wheel can't get to it.)
    Problem is there's damn near a credit cards thickness of paint/powdercoat/whatever and the sandblaster doesn't anything.
    Re: Supercharger paint removal
    I think its baked on enamel. I blast off the loose stuff and then use the blaster to roughen everything else. Clean and paint over.
